Comware 5 with CPPM captive portal
  • 1.  Comware 5 with CPPM captive portal
    Posted Nov 03, 2017 11:06 PM
    Gurus,
    Switch: HP 5500 (comware 5)
    i'm able to do 802.1x and mac auth but seems to fail at captive portal redirection to register user that fail 802.1x and in such away able to onboard their device
    is it because comware 5 doesnt support coa that cause im unable to redirect?
    what is the correct config on switch and clearpass side. is it need to do URL av pair?
  • 2.  RE: Comware 5 with CPPM captive portal
    Posted Nov 03, 2017 11:28 PM
    Comware 5 does not support external captive portal redirection.
  • 3.  RE: Comware 5 with CPPM captive portal
    Posted Nov 03, 2017 11:31 PM
    how about the portal free rule that i saw in several post
  • 4.  RE: Comware 5 with CPPM captive portal
    Posted Nov 03, 2017 11:33 PM
    if that the case..
    the only demo i can show to the user is typical 802.1x and mac auth then..
    but not sure profillng will work or not..due to coa is not there...
  • 5.  RE: Comware 5 with CPPM captive portal
    Posted Nov 03, 2017 11:40 PM
    Comware 5 has a very limited featureset.
  • 6.  RE: Comware 5 with CPPM captive portal
    Posted Nov 03, 2017 11:44 PM
    can we do mac auth..and profile device at the same time? without having reconnecting the device...?
  • 7.  RE: Comware 5 with CPPM captive portal
    Posted Dec 19, 2018 12:31 PM
    TIM, is there the possibility of using the internal captive portal of Comware 5 and perform the user validation in the ClearPass?
  • 8.  RE: Comware 5 with CPPM captive portal
    Posted Dec 19, 2018 01:17 PM
    We have not done any validation with the legacy v5 platform. I don't believe any external captive portal redirect is supported.
