Network Management
Comware 7 AND AirWave Management Platform 8.2.4.3 interface issue
  • 1.  Comware 7 AND AirWave Management Platform 8.2.4.3 interface issue
    Posted Jun 10, 2019 08:19 AM
    Hello Guys,
    Have you an excellent week!
    I´m facing an issue in my Airwave to show the interface information by my Comwares 7. The Comware 5 is working fine.
    Error:
    Mon Jun 10 12:03:12 2019 System Error in SNMP polling: Unknown error(interface_monitor)
    ...omitted 28 duplicate messages...
    Mon Jun 10 11:33:03 2019 System Error in SNMP polling: Unknown error(interface_monitor)
    In a summary the procedure I followed was:
    1 - Register using another category as "Custom Device", "Router/Switch" and "Universal Network Device"
    2 - Following the procedure suggested from Eric to allow all SNMP version in Comware:
    Post regard this subject: https://community.arubanetworks.com/t5/Network-Management/Comware-units-and-Airwave-8-2-7/td-p/459493
    3 - Remove and add a lot of times using different information and configuration.
    Please, let me know if you have any suggestion to follow.
  • 2.  RE: Comware 7 AND AirWave Management Platform 8.2.4.3 interface issue
    Posted Jun 10, 2019 01:54 PM
    Adding a device as Universal Network device, it should just work, as long as the device supports the basic networking OID's such has, systemp up/down, uptime etc.
    However, in the 8.2.4.x Airwave supported guide, i see the below list:
    HPE 1950 Switch 2220P02 (Comware 7) HPE 3100 Switch Series 2220P02 (Comware 7) HPE 3600 Switch Series 2220P02 (Comware 7) HPE 5120 Switch 2220P02 (Comware 7) HPE 5130 Switch 2220P02 (Comware 7) HPE 5500 Switch Series 2220P02 (Comware 7) HPE 7500 Switch Series 2220P02 (Comware 7) HPE 10500 Switch Series 2220P02 (Comware 7)
    which type of comware are you using?  attached is the supported guide for your reference.
    Attachment(s)
  • 3.  RE: Comware 7 AND AirWave Management Platform 8.2.4.3 interface issue
    Posted Jun 10, 2019 02:17 PM
    Hello
    Thanks for your fast reply!
    Considering I´m using the AirWave Management Platform 8.2.4.3, I took as reference the guides below:
    Supported Infrastructure Devices:
    AirWave 8.2.7.1:
    > https://support.hpe.com/hpsc/doc/public/display?docId=emr_na-a00059666en_us&docLocale=en_US
    AirWave 8.2.8.2:
    > https://support.hpe.com/hpsc/doc/public/display?docId=emr_na-a00065969en_us&docLocale=en_US
    The equipment I´m using is a Comware 5700 using the Release 2432P06 (Bootrom Version: 157)
    Before I create the post I tried adding as a Universal Network Device without effect.
    @Fayyaz Mohammed wrote:
  • 4.  RE: Comware 7 AND AirWave Management Platform 8.2.4.3 interface issue
    Posted Jun 10, 2019 02:28 PM
    Hello, yes, it looks like you are using Federal version of Airwave, which is 8.2.4.3, you will need to look for the reference documents only belong to 8.2.4.x versions, not 8.2.7.x etc.
    if you add universial device and it is not working, could you please message me your email address as a private message, i can work with you, and update the solution on this post, once we finish working?
  • 5.  RE: Comware 7 AND AirWave Management Platform 8.2.4.3 interface issue
    Posted Jun 10, 2019 02:42 PM
    Perfect!
    We can do it, let me know your email and We can work together with this issue.
    Or please, send to me an email: gustavo.andrade@sercompe.com.br
  • 6.  RE: Comware 7 AND AirWave Management Platform 8.2.4.3 interface issue
    Posted Jun 11, 2019 02:50 PM
    Hello Gustavo,
    As discussed, This switch is not yet supported in the federal version of Airwave, which is 8.2.3.4, However, it is supported in the regular version of 8.2.7.x and above.
    I would recommend you to get in touch wtih the Sales Team, they can inform you in which version, we are planning to implement this supportablility. please let me know if you have any queries.
    hope this helps..
  • 7.  RE: Comware 7 AND AirWave Management Platform 8.2.4.3 interface issue
    Posted Jun 11, 2019 03:12 PM
    Hello Fayyas,
    Thank you so much for our meeting and explanation about the issue.
    As a partner I understand this gap and I will get in touch with my Sales Team.
    Hello Gustavo,
    hope this helps..
    Have you a great day!
