Is it known as non working, to have a GRE tunnel formed in one VRF and bind the tunnel in other VRF ? Something like:
ip vpn-instance VRF-2-RED
route-distinguisher 203333:2
description RED
ip vpn-instance VRF-4-GREEN
route-distinguisher 203333:4
description GREEN-VRF
interface Vlan-interface3511
description RED
ip binding vpn-instance VRF-2-RED
ip address 21.11.13.18 255.255.255.252
ipv6 address 2001:DB8:AF00:21::1/64
interface Tunnel1 mode gre
description TUN-R1
shutdown
ip binding vpn-instance VRF-4-GREEN
ip address 10.4.1.14 255.255.255.252
source 21.11.13.18
destination 10.17.56.2
tunnel vpn-instance VRF-2-RED
ipv6 address FD05:DB8:0:1::2/64
GRE tunnels on 5920AF-24XG Switch running HPE Comware 7.1.045 (2432P05) the GRE is up the OSPF and BGP seesions are up, but something goes wrong on the return path, there is nothing wrong with how the routing and route leaking is configured as I have another phisical link for backup, where this works fine.
In HPE VSR1000 this works without a problem.
#vpn-instance#5920AF#GRE
