Hi there. I probably missed a post with the answer when I searched for this but here I go.
Background, I am used to procurve and now made the move to a new comware based core.
My previous setup was a procruve connected to another procurve with LACP trunks with all vlan tagged on the trunk.
The new setup with which I am having an issue is a procurve and comware connected to another with LACP.
The trunk conf on procurve is straight forward:
trunk J1-J4 trk60 lacp
then this trk60 is tagged in each vlan of interest (1,99,100).
The bridge aggregation on comware is also ok:
interface Bridge-Aggregation10
port link-type trunk
port trunk permit vlan all
link-aggregation mode dynamic
And the interfaces of interest are in the bagg accordingly
interface GigabitEthernet1/0/10
port link-mode bridge
port link-aggregation group 10
You will note I am doing permit vlan all too.
On the procurve, my LACP looks good.
LACP Trunk Port LACP Admin Oper
Port Enabled Group Status Partner Status Key Key
J1 Active Trk60 Up Yes Success 0 349
J2 Active Trk60 Up Yes Success 0 349
J3 Active Trk60 Up Yes Success 0 349
J4 Active Trk60 Up Yes Success 0 349
On the comware, my BAGG also looks good
Loadsharing Type: Shar -- Loadsharing, NonS -- Non-Loadsharing
Port Status: S -- Selected, U -- Unselected
Flags: A -- LACP_Activity, B -- LACP_Timeout, C -- Aggregation,
D -- Synchronization, E -- Collecting, F -- Distributing,
G -- Defaulted, H -- Expired
Aggregation Interface: Bridge-Aggregation10
Aggregation Mode: Dynamic
System ID: 0x8000, 7848-5952-8f88
Local:
Port Status Priority Oper-Key Flag
GE1/0/10 S 32768 1 {ACDEF}
GE1/0/11 S 32768 1 {ACDEF}
GE2/0/10 S 32768 1 {ACDEF}
GE2/0/11 S 32768 1 {ACDEF}
Remote:
Actor Partner Priority Oper-Key SystemID Flag
GE1/0/10 217 0 349 0xcf00, 0018-71ca-cf00 {ACDEF}
GE1/0/11 219 0 349 0xcf00, 0018-71ca-cf00 {ACDEF}
GE2/0/10 218 0 349 0xcf00, 0018-71ca-cf00 {ACDEF}
GE2/0/11 220 0 349 0xcf00, 0018-71ca-cf00 {ACDEF}
however...
While everything connected on my procurve untagged on vlan 99 and 100 is fine and reach the comware, what is untagged on vlan 1 doesn't.
now I perhaps lack comprehension of comware but here is what I think.
on comware, if I look at vlan 99 and 100 I see that the BAGG (and the member ports) is tagged.
>dis vlan 100
VLAN ID: 100
VLAN Type: static
Route Interface: not configured
Description: VLAN 0100
Tagged Ports:
GigabitEthernet1/0/10 GigabitEthernet1/0/11 GigabitEthernet2/0/10
GigabitEthernet2/0/11
Ten-GigabitEthernet1/0/29
Ten-GigabitEthernet1/0/30
Ten-GigabitEthernet2/0/29
Ten-GigabitEthernet2/0/30
Untagged Ports: none
but on vlan 1 the BAGG is untagged.
>dis vlan 1
VLAN ID: 1
VLAN Type: static
Description: VLAN 0001
Tagged Ports: none
Untagged Ports:
GigabitEthernet1/0/1 GigabitEthernet1/0/2 GigabitEthernet1/0/3
GigabitEthernet1/0/4 GigabitEthernet1/0/5 GigabitEthernet1/0/6
GigabitEthernet1/0/7 GigabitEthernet1/0/8 GigabitEthernet1/0/9
GigabitEthernet1/0/10 GigabitEthernet1/0/11 GigabitEthernet1/0/12
GigabitEthernet1/0/13 GigabitEthernet1/0/14 GigabitEthernet1/0/15
GigabitEthernet1/0/16 GigabitEthernet1/0/17 GigabitEthernet1/0/18
GigabitEthernet1/0/19 GigabitEthernet1/0/20 GigabitEthernet1/0/21
GigabitEthernet1/0/22 GigabitEthernet1/0/23 GigabitEthernet1/0/24
GigabitEthernet1/0/25 GigabitEthernet1/0/26 GigabitEthernet1/0/27
GigabitEthernet1/0/28 GigabitEthernet2/0/1 GigabitEthernet2/0/2
GigabitEthernet2/0/3 GigabitEthernet2/0/4 GigabitEthernet2/0/5
GigabitEthernet2/0/6 GigabitEthernet2/0/7 GigabitEthernet2/0/8
GigabitEthernet2/0/9 GigabitEthernet2/0/10 GigabitEthernet2/0/11
GigabitEthernet2/0/12 GigabitEthernet2/0/13 GigabitEthernet2/0/14
GigabitEthernet2/0/15 GigabitEthernet2/0/16 GigabitEthernet2/0/17
GigabitEthernet2/0/18 GigabitEthernet2/0/19 GigabitEthernet2/0/20
GigabitEthernet2/0/21 GigabitEthernet2/0/22 GigabitEthernet2/0/23
GigabitEthernet2/0/24 GigabitEthernet2/0/25 GigabitEthernet2/0/26
GigabitEthernet2/0/27 GigabitEthernet2/0/28
so here I go, the issue seem to be that I have a BAGG with port-link mode trunk that is untagged? hence not getting my vlan 1 traffic from the procurve? if so how do I "tagged" my BAGG on vlan1?
or perhaps I am mixing up the terms and miss something because when I had only procurve, this conf with the lacp trunk tagged on all vlans it did not require much more config.
#comware#bagg#ProCurve#VLAN
