Comware critical VLAN (and clearpass)
  • 1.  Comware critical VLAN (and clearpass)
    Posted Nov 09, 2021 06:05 AM
    I'm currently meeting an issue regarding Comware v7 critical vlan.
    When I try to disconnect clearpass to test critical vlan, critical vlan on comware are not working but configured as well.
    vlan 30 is a vlan that assign DHCP response currently.
    But when I disconnect clearpass, computer Don't receive an IP address, and so the critical vlan 30 is not used.
    ​Here is my configuration :
    interface GigabitEthernetX/0/X
    stp edged-port
    mac-authentication max-user 10
    mac-authentication critical vlan 30
    mac-authentication host-mode multi-vlan
    port-security port-mode userlogin-secure-or-mac-ext
    dot1x critical vlan 30
    I tried both domain radius in 2 configurations (with local fallback, and without):
    Domain radius
    authentication lan-access radius-scheme clearpass local
    authorization lan-access radius-scheme clearpass local
    accounting lan-access radius-scheme clearpass local
    Domain radius
    Lawrence BENEDICT
  • 2.  RE: Comware critical VLAN (and clearpass)
    MVP GURU
    Posted Nov 09, 2021 09:02 AM
    Are you matching the scenario you want correctly?
    Dustin Burns
    Lead Mobility Engineer @WEI
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2021
