Comware
Comware Sending ACL logs to Snmp Agent
  • 1.  Comware Sending ACL logs to Snmp Agent
    Posted Apr 21, 2016 11:12 AM
    Hello all,
    I just had a question regarding the info-center and snmp-agent configuarations. Currently i have a HP 5500 Switch which has an ACL rule setup to block IP packets from a specified address. The acl works and was defined as such (Where X's are used to represent an IP address):
    rule 0 deny ip source X.X.X.X 0 destination X.X.X.X 0 logging
    When i log into the web interface and look at the syslog im able to see logs that show all the traffic and acl blocks; however im not recieving any of those notifications on my snmp-agent. On the snmp agent im only getting messages from the trapbuffer (link up/down, ssh connections, web connections...etc). I was just wondering if anyone has any suggestions or ideas on how i can configure this properly; I've reffered to the manual but still seem to be having trouble with this. In the info center ive setup the TRAP, DEBUG and LOG levels to informational so i thought this should work.
    info-center source default channel 5 log state on trap level debugging debug state on
    Thanks again for any help.
    #packet-filter
    #HP
    #comware
    #3Com
    #ACL
    #com3
    #logs
    #snmp
    #switches
