Network Management
Config job saving commware
  • 1.  Config job saving commware
    Posted Oct 05, 2018 04:23 PM
    Hey Guys,
    I have ~100-125 hp 1920 switches where i am trying to add the NTP/DST settings to via airwave.  I have set up a config job and pushing out the 3 lines i need and it works great.  The issue is that it doesn't save the config, so if the switch reboots i lose my settings.  I tried to add the following to the bottom of my config job
    save
    y
    y
    This works if i telnet into the switch and run it.  It says, y to config the blank for the enter to overwrite the startup.cfg and a y to confirm again.  The blank i use for enter doesn't translate well when used in a config job and it doesn't work.
    I was able to get around this with a save force.  It creates a startup-bak.cfg file as a back up and does successfully save the switch.  Is this going to cause any problems or should i proceed with the save force?
    I am open to other ways but i was hoping to do it nicely via Airwave.
    Thanks for any input.
  • 2.  RE: Config job saving commware
    Posted Oct 08, 2018 10:18 AM
    Please open a TAC case so that support can have a closer look into the issue.
