Config management port on aruba 3600
  • 1.  Config management port on aruba 3600
    Posted Oct 15, 2012 10:09 AM
    I need to configure the management port on my 3600 to have a assigned IP. Can some one shed some light?
    #3600
  • 2.  RE: Config management port on aruba 3600
    Posted Oct 15, 2012 10:22 AM
    The management port on the 3600 is a serial interface, so it cannot have an ip address.
    You can assign a loopback address, but it is not tied to that physical port.
  • 3.  RE: Config management port on aruba 3600
    Posted Oct 15, 2012 10:26 AM
    correction. I need to assighn an ip to a port so I can manage the 3600 from a different subnet on my network
  • 4.  RE: Config management port on aruba 3600
    Posted Oct 15, 2012 10:29 AM
    You would then:
    - create a VLAN on the controller.
    - Add an IP address to that VLAN.
    - Add that VLAN to a port.
    - Make sure you can ping that ip address from your infrastructure.
    Remember that the controller can be managed from any ip address on any of its interfaces...
  • 5.  RE: Config management port on aruba 3600
    Posted Oct 15, 2012 10:31 AM
    thank you for the quick response
