config mobility controller and clearpass
  • 1.  config mobility controller and clearpass
    Posted Nov 10, 2016 01:28 PM
    I'm trying to connect my Aruba MC 7210 to my ClearPass 6.6 appliance but I get radius error.
    1. In ClearPass - I Configured my MC 7210 "\Configuration\Network\Devices\"
    2. In MC 7210 - I configured my Radius Server(ClearPass)
    "\Configuration\authentication\Servers\Radius Server"
    3. In MC 7210 - I configured my Server Group
    "\Configuration\authentication\Servers\Server Group"
    4. In MC 7210 - I configured my RFC 3576 Server(ClearPass)
    "\Configuration\authentication\Servers\RFC 3576 Server"
    5. In MC 7210 - I configured my WLAN pointing to Radius Server
    And I receive Radius Server Authentication Error. What can I do?
    Here we have some logs...
    [Th 13 Req 5 SessId R00000005-01-5824b6c9] ERROR RadiusServer.Radius - rlm_service: Service Categorization failed
    [Th 13 Req 5 SessId R00000005-01-5824b6c9] ERROR RadiusServer.Radius - rlm_service: Policy Server result = 65535, msg = Service classification failed
    [RequestHandler-1-0x7f08245e2700 r=psauto-1478731079-11 h=223 r=R00000005-01-5824b6c9] ERROR Core.ServiceReqHandler - doServiceClassification: Error. Ret code=0 response list size=0
  • 2.  RE: config mobility controller and clearpass
    Posted Nov 10, 2016 01:34 PM
    Please post a screenshot of your service.
  • 3.  RE: config mobility controller and clearpass
    Posted Nov 10, 2016 01:41 PM
  • 4.  RE: config mobility controller and clearpass
    Posted Nov 10, 2016 01:53 PM
    OK. Look through the input tab in the access tracker request and make sure
    those all match. Also, remove rule 3.
  • 5.  RE: config mobility controller and clearpass
    Posted Nov 10, 2016 02:04 PM
    Hi, All this information is correct, I removed rule 3 and is the same
  • 6.  RE: config mobility controller and clearpass
    Posted Nov 10, 2016 02:08 PM
    Your SSID rule is likely the issue. You're searching for "secure", but the
    SSID is "DigiWorld.Aruba"
  • 7.  RE: config mobility controller and clearpass
    Posted Nov 10, 2016 02:15 PM
    Thanks a lot, I solved it and now I get this
    ERROR RadiusServer.Radius - rlm_peap: Configured for public mode, but request username hrojas does not match public username public, rejecting
    How can I config the Authentication without public mode?
  • 8.  RE: config mobility controller and clearpass
    Posted Nov 10, 2016 02:17 PM
    If you're not using EAP-PEAP-Public, remove EAP-PEAP-Public from the
    authentication methods list and add EAP-PEAP.
  • 9.  RE: config mobility controller and clearpass
    Posted Nov 10, 2016 02:19 PM
    Yes, but I dont't have that choise. Can't I use EAP-MSChap2?
  • 10.  RE: config mobility controller and clearpass
    Posted Nov 10, 2016 02:22 PM
    Are you using a RADIUS service? You should definitely have an [EAP PEAP]
    option in the list. Please provide a screenshot.
  • 11.  RE: config mobility controller and clearpass
    Posted Nov 10, 2016 02:31 PM
  • 12.  RE: config mobility controller and clearpass
    Posted Nov 10, 2016 02:37 PM
    You have high capacity guest mode enabled. You can only use EAP-PEAP Public
    in this mode.
  • 13.  RE: config mobility controller and clearpass
    Posted Nov 10, 2016 02:44 PM
    Yes and how can I use anthore methods?
  • 14.  RE: config mobility controller and clearpass
    Posted Nov 10, 2016 02:49 PM
    You cannot use other EAP methods in HCG mode. It is designed for scaling in
    large guest deployments.
  • 15.  RE: config mobility controller and clearpass
    Posted Nov 10, 2016 03:00 PM
    Thanks a lot, now I can surf using my WLAN and ClearPass
    This solutions is oriented to a hotel and good for me to use HCG mode.
    Can I use another methods for authentication??
  • 16.  RE: config mobility controller and clearpass
    Hi, All this information is correct, I removed rule 3 and is the same.
    Logs:
