Aruba Central
last person joined: 2 hours ago
Config Status "Not in Sync"
This thread has been viewed 21 times
  • 1.  Config Status "Not in Sync"
    Posted Mar 06, 2024 11:32 AM
    I have three AOS-CX 6100 switches and the are In sync in the default group.
    When I want to move them to my group, where my 41 AP-515 are in, the switches give the config status "not in sync".
    How can I get the switches in that group with the config status in sync ?
    Second question can I move the DHCP from VLAN 1 to another VLAN ?
    Bart Engelen
  • 2.  RE: Config Status "Not in Sync"
    Posted Mar 06, 2024 12:08 PM
    There is likely a configuration held on the Default Group context that is missing from your destination group.
    You would want to make sure those Groups have a mirrored configuration for critical components.
    Or when you move the device, you could test retaining the original configuration - see below.
    You maybe able to see the the Sync Issue or Local Overrides by navigating to: the specific device > Device > Config > Configuration Status
    If my post was useful, please Accept Solution and Give Kudos.
    Zak Chalupka
    Principal Engineer - HPE Aruba
    ACDX | ACMP | ACSP | ACCP
    wifizak@hpe.com
    Ideas expressed here are solely my own and not necessarily that of HPE Aruba.
  • 3.  RE: Config Status "Not in Sync"
    Posted Mar 06, 2024 02:50 PM
    Thanks for your answer.
    I got this in the configuration status page, on all three devices.
  • 4.  RE: Config Status "Not in Sync"
    Posted Mar 06, 2024 03:21 PM
    You would now need to explore what "Pending Changes" are not sync'd. As well as what "Local Overrides" are still applied to the switch.
    At that point you can decide to eliminate those local overrides or add them to your destination group configuration.
    Zak Chalupka
    wifizak@hpe.com
  • 5.  RE: Config Status "Not in Sync"
    Posted Mar 06, 2024 03:33 PM
    I am very new to Aruba Central.
    How can I explore the what "Pending Changes" ?
    I see the local Overrides but the settings in Aruba Central are correct and working on my switches.
    How can I get ride of this overrides?
  • 6.  RE: Config Status "Not in Sync"
    Posted Mar 06, 2024 03:55 PM
    Below is a guide that explains these status items:
    Clicking on the links of those items will show/highlight the configuration lines where there is a mismatch.
    Zak Chalupka
    wifizak@hpe.com
