Config syslog in controller
  • 1.  Config syslog in controller
    Posted Jul 27, 2015 04:01 AM
    Can I disable AP’s log sending from controller? It is because after enable log from controller, all controller and AP’s log will keep sending into the log server.
  • 2.  RE: Config syslog in controller
    Posted Jul 27, 2015 06:16 AM
    It is possible, you should not select "All" under the Category while you are adding the server.
    for your ref:
    Please feel free for any further help on this.
