Configuration Backup/Restore on different instant ap
  • 1.  Configuration Backup/Restore on different instant ap
    Posted May 07, 2015 12:10 AM
    Hi AirHeads.
    Can I backup a configuration on IAP225 and restore it to IAP205 ?
    Is it not recommended ?
    What will happen when I restore the configuration to IAP205 using backup configuration file (instant.cfg) of IAP225 both ethernets are enabled ?
  • 2.  RE: Configuration Backup/Restore on different instant ap
    Posted May 07, 2015 01:27 AM
    HI,
    As per my knowledge It is not possible because of different hardware, IAP 225 is Centaurus and 204 is Taurus.
  • 3.  RE: Configuration Backup/Restore on different instant ap
    Posted May 07, 2015 03:39 AM
    Thank you for reply.
    It seems that "instant.cfg" is just configuration file and doesn't include something to check OS or platform.
    NTL, is there no backup/restore function compatibility between different OS platform?
    (Support Policy doesn't permit it ? or I can't succeed operation ?)
    If so, can I do backup the configuration of IAP204-A and restore it to IAP205-B ?
  • 4.  RE: Configuration Backup/Restore on different instant ap
    Posted May 07, 2015 04:46 AM
    On the Maintenance>Configuration Tab, there is a checbox below.
    "remove all configuration including per-AP settings and certificates"
    Doesn't this ensure the compatibility of configuretion backup/restore between different hardware ?
    And in the last hour, I tried restoring the instant.cfg to IAP205 from backup of IAP109.
    Restoring was succeed.
    Is it true that "it is not possible" ?
    Thank you.
    Atsushi Ikeda
  • 5.  RE: Configuration Backup/Restore on different instant ap
    Posted May 08, 2015 02:20 AM
    we can do as written by subject of this post.
    As long as their version is same , we can do backup/restore between different class models.
    answer is wrong.
