Configuration Guide Aruba AP505H
  • 1.  Configuration Guide Aruba AP505H
    Posted Dec 01, 2023 10:47 AM
    I habe a problem to find proper documentation how to configure a Aruba 505H. The AP has been succesfully been discoverd by our Mobility controllers a,d I can configure the wireless part of this device but I did not find any documentation or installation guide how you can configure the 4 network ports with different vlan's or even with clearpass (Nac). Can someone help where i can find this documentation?
    Ps: Also on the asp portal I can't find anything about this , only for the instant but this is not an instant AP or a RAP
  • 2.  RE: Configuration Guide Aruba AP505H
    Posted Dec 01, 2023 11:06 AM
    An AP group can be configured with up to 5 port profiles (enet0 - enet4).
    https://www.arubanetworks.com/techdocs/CLI-Bank/Content/aos8/ap-group.htm
    The port profiles can be configured to enable/disable a port, define AAA profile for ClearPass, configure spanning-tree, loop protect, etc.
    https://www.arubanetworks.com/techdocs/CLI-Bank/Content/aos8/ap-wired-prt-pro.htm
    The VLANs are configured in the wired AP profile.
    https://www.arubanetworks.com/techdocs/CLI-Bank/Content/aos8/ap-wired-ap-pro.htm
    Josh
  • 3.  RE: Configuration Guide Aruba AP505H
    Posted Dec 04, 2023 07:12 AM
    If you're looking for this via the GUI, follow:
    Managed Network folder > Config > System > Profiles > AP > AP Group > select the relevant group and scroll down to see the ports
    But you need to make a wired port profile first to apply to the ports, follow:
    Managed Network folder > Config > System > Profiles > AP > AP Wired Port > create a new profile and away you go.
    Nathan
