If you're looking for this via the GUI, follow:
Managed Network folder > Config > System > Profiles > AP > AP Group > select the relevant group and scroll down to see the ports
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/169935e2b5904c57a7f4d0c2c75bda7f.png)
But you need to make a wired port profile first to apply to the ports, follow:
Managed Network folder > Config > System > Profiles > AP > AP Wired Port > create a new profile and away you go.
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/c67558210007491e9074722af300f0c4.png)
Nathan
Original Message:
Sent: Dec 01, 2023 10:47 AM
Subject: Configuration Guide Aruba AP505H
I habe a problem to find proper documentation how to configure a Aruba 505H. The AP has been succesfully been discoverd by our Mobility controllers a,d I can configure the wireless part of this device but I did not find any documentation or installation guide how you can configure the 4 network ports with different vlan's or even with clearpass (Nac). Can someone help where i can find this documentation?
Ps: Also on the asp portal I can't find anything about this , only for the instant but this is not an instant AP or a RAP
