Wired Intelligent Edge
Configuration migration from 5406zl to 5406zl2
  • 1.  Configuration migration from 5406zl to 5406zl2
    Posted Apr 18, 2019 07:53 AM
    Hello All,
    I'm planning to replace 5406zl  with the new Aruba 5406zl2,
    to migrate the configuration the existing configuration I'm thinking about something easy like copy/past running configuration from old zl to the new zl2 ... is that right ?
    is there any guide/recommendations/best practice for that?
  • 2.  RE: Configuration migration from 5406zl to 5406zl2
    Posted Apr 18, 2019 08:46 AM
    The configuration is almost the same. If you are going to use VSF you need to update the port numbers.
    But if the port numbering is almost the same copy/past should work. Depends also on the complexity of the configuration
