Cloud Managed Networks
Configuration switchport modules Aruba Central
  • 1.  Configuration switchport modules Aruba Central
    Posted Jun 18, 2020 03:28 AM
    Hi all,
    I just want to be sure, before I order Aruba switchport modules.
    Is it possible to configure Aruba 3810M/2930M modules in Aruba Central UI config groups? Maybe on device level in an UI config group?
    As far as I see, I can only configure ports 1-52 in an UI config group on group level.
    Example:  Aruba 3810M/2930M 4-port 100M/1G/10G SFP+ MACsec module - JL083A
    Kind regards,
    Berten
  • 2.  RE: Configuration switchport modules Aruba Central
    Posted Jun 18, 2020 07:26 AM
    I am sure, that you can just configure the ports, which are physically there.
    So if you have a module, like the one you mentioned, it will appear as the amound of ports it contains, in this case A1-A4 or B1-B4
    Regards
