Configure 2 Networks over 2 Ethernet Network Cards on ARUBA 235 AP
  • 1.  Configure 2 Networks over 2 Ethernet Network Cards on ARUBA 235 AP
    Posted Apr 20, 2017 06:07 AM
    i wanted to Configure 2 SSIDs, using both ethernet network cards on the AP. Every networkcard has its own IP Segment and a IP-address from 2 differend DHCP Servers. One SSID is for company access, the other for guest access. How can i configure a new SSID which uses just one network card on the AP?
    I could configure the switchports in the "Tagged" mode, so the APs could funciton as DHCP Server.
    Thanks!
