Wired Intelligent Edge
last person joined: 10 hours ago
Configure 2930f
  • 1.  Configure 2930f
    Posted Jun 02, 2017 02:01 PM
    Hi
    I'm new with Aruba-switches.
    My schematic :
    When i put a pc in port 1 (IP 10.10.100.101 - GW 10.10.100.254) , I can manage all the switches and go on the internet.
    Now what should I do for the following:
    Put a pc in port 5 of the 1210-16 so he get an IP (from dhcp on vlan30) and then this pc allow to go on the internet?
    Thx for help
    Delan
  • 2.  RE: Configure 2930f
    Posted Jun 06, 2017 02:22 AM
    Hi Delan,
    Just to verify I think you mean VLAN 20 right? Do you get an IP with correct default gateway from DHCP? Do you have ip routing enabled on the 2930f?
    Regards, Dobias
  • 3.  RE: Configure 2930f
    Posted Jun 06, 2017 10:33 AM
    Hi Dobias
    yes , I have set all the ip-addresses manualy as in the schema.
    IP routing is on.
    The gateway's of the pc's (per vlan) are the ip addresses of the vlan interfaces.
    I was struggling today and had no result.
    It's like the routing isn't work.
    I checked and the switch is in L3-mode.
  • 4.  RE: Configure 2930f
    Posted Jun 07, 2017 02:09 AM
    hi
    I setup a test environment
    The pfsense 10.70.200.254
    switch 2930f :
    Running configuration:
    ; JL259A Configuration Editor; Created on release #WC.16.03.0004
    ; Ver #10:08.3f.ff.bb.ef.7c.59.fc.6b.fb.9f.fc.ff.ff.37.ef:7e
    hostname "Core"
    module 1 type jl259a
    ip default-gateway 10.70.200.254
    ip routing
    snmp-server community "public" unrestricted
    vlan 1
    name "DEFAULT_VLAN"
    no untagged 13-14
    untagged 1-12,15-28
    ip address 10.70.200.11 255.255.255.0
    exit
    vlan 100
    name "VLAN100"
    untagged 13-14
    tagged 24
    ip address 10.70.201.12 255.255.255.0
    exit
    no tftp server
    no autorun
    no dhcp config-file-update
    no dhcp image-file-update
    password manager
    Core(config)#
    Core(config)# sh ip
    Internet (IP) Service
    IP Routing : Enabled
    Default TTL : 64
    Arp Age : 20
    Domain Suffix :
    DNS server :
    | Proxy ARP
    VLAN | IP Config IP Address Subnet Mask Std Local
    DEFAULT_VLAN | Manual 10.70.200.11 255.255.255.0 No No
    VLAN100 | Manual 10.70.201.12 255.255.255.0 No No
    Core(config)#
    Core(config)# sh ip route
    IP Route Entries
    Destination Gateway VLAN Type Sub-Type Metric Dist.
    10.70.200.0/24 DEFAULT_VLAN 1 connected 1 0
    10.70.201.0/24 VLAN100 100 connected 1 0
    127.0.0.0/8 reject static 0 0
    127.0.0.1/32 lo0 connected 1 0
    Core(config)#
    This are all the settings
    PC1 (in port 1)
    IP : 10.70.200.101 - GW : 10.70.200.254 - MASK : /24
    PC2 (in port 13)
    IP : 10.70.201.102 - GW : 10.70.201.12 - MASK : /24
    (also tried with GW : 10.70.200.254)
    From PC 1 ok to internet, no ping to pc2
    From PC2 no internet and no ping to pc1
    I don't understand it ????
    Help please
    Where can I try something?
    THX
  • 5.  RE: Configure 2930f
    Posted Jun 07, 2017 02:49 AM
    Hi
    I made a test environment :
    The pfsense is 10.70.200.254 /24 in port 24
    Switch settings :
    Core# sh ru
    hostname "Core"
    ip routing
    vlan 1
    name "DEFAULT_VLAN"
    no untagged 13-14
    untagged 1-12,15-28
    exit
    vlan 100
    name "VLAN100"
    untagged 13-14
    tagged 24
    exit
    no tftp server
    no autorun
    password manager
    Core# sh ip
    Default TTL : 64
    Arp Age : 20
    Domain Suffix :
    DNS server :
    | Proxy ARP
    Core# sh ip route
    IP Route Entries
    The PC's
    PC1 in port 1
    IP : 10.70.200.101 - GW : 10.70.200.254 MASK : /24
    PC2 in port 13
    IP : 10.70.201.102 - GW : 10.70.201.12 MASK : /24
    PC1 : internet ok, ping to pc2 is not ok
    PC2 : internet not ok, ping to pc1 not ok
    on pc2 also tried with GW : 10.70.200.254 (same result)
    I can't understand. I think there is something ...... I don't see it.
    Help please !!
    THX
  • 6.  RE: Configure 2930f
    Posted Jun 07, 2017 01:54 PM
    Let's start to break this down. In your last example you mentioned PC2 couldn't ping PC1. This was done from 2930f in port 13 right? Can you ping VLAN100 and VLAN1 IP when PC2 is connected in this port 13?
  • 7.  RE: Configure 2930f
    Posted Jun 07, 2017 02:05 PM
    I'm sorry not sure but was logged in with my wrong username. Just checking your config again and see that you configured ip default-gateway. This command set-up routing for switch itself (for e.g. management) when ip routing is disabled. You need to configure static default route via ip route 0.0.0.0 0.0.0.0 x.x.x.x for the router itself. Hope this helps!!
  • 8.  RE: Configure 2930f
    Posted Jun 07, 2017 04:00 PM
    Hi Dobias
    I already tried this. no ip routing and then ip rout 0.
    0.0.0 0.0.0.0 10.70.200.254 (the default gateway)
    That was'nt WORKING :-(
    I have already did hard resets to factory ....
    No result
    Delan009
  • 9.  RE: Configure 2930f
    Posted Jun 07, 2017 04:17 PM
    It's the other way around. Enable IP routing and than ip route 0.0.0.0 0.0.0.0 x.x.x.x to add static default. IP default gatway is used when ip routing is disabled for switch itself.
  • 10.  RE: Configure 2930f
    Posted Jun 08, 2017 01:57 AM
    Hi Dobias
    here my switch settings (as your recomm.)
    Core(config)# sh ru
    hostname "Core"
    ip route 0.0.0.0 0.0.0.0 10.70.200.254
    ip routing
    router rip
    redistribute connected
    enable
    exit
    vlan 1
    name "DEFAULT_VLAN"
    no untagged 13-14
    untagged 1-12,15-28
    exit
    vlan 100
    name "VLAN100"
    untagged 13-14
    tagged 24
    exit
    spanning-tree
    no tftp server
    no autorun
    password manager
    IP Route Entries
    0.0.0.0/0 10.70.200.254 1 static 1 1
    Core(config)# sh ip
    Default TTL : 64
    Arp Age : 20
    Domain Suffix :
    DNS server :
    | Proxy ARP
    Now it's more bad :
    PC1 can ping to def.gateway (10.70.200.254) and internet
    PC1 can't ping any more to VLAN100 ip (10.70.201.102)
    PC 2 can only ping to his interface (10.70.201.12) and nothing else.
    My feeling is that there is something wrong with this switch !
    THX for your tips and followup. So I feel not alone :-)
    Delan009
  • 11.  RE: Configure 2930f
    Posted Jun 08, 2017 02:29 AM
    8-) can't say for sure but don't think there is anything wrond with this switch. Just tried on same switch and everything is working fine but let's see. Can you please remove ip default-geway command from your config? Do you need dynamic routing protocol? I see you using rip but from the diagram I only see directly connected routes from the switch. If you don't need dynamic routing can you also please delete router rip from confgiuration. Let's now first make sure PC1 and PC2 can big their own gateways and each other when connected on the same switch. Than we will move to other switches and to internet gateway.
  • 12.  RE: Configure 2930f
    Posted Jun 08, 2017 04:10 AM
    first of all... does your GW(10.70.200.254) know of VLAN100?
    to test you must change gateway of PC1 to 10.70.200.11,
    then try your pingtests again.
    you now should be able to ping PC2 from P
    my guess would be that you are only missing a route on the gateway...!
    hth..
    Alex
  • 13.  RE: Configure 2930f
    Posted Jun 08, 2017 04:24 AM
    Hi ALex,
    That would indeed explain traffic comming from the PFsense so internet  but traffic between PC1 en PC2 needs to be routed via 2930f from what I understood.
  • 14.  RE: Configure 2930f
    Posted Jun 08, 2017 06:13 AM
    Hi Dobias
    I hard reseted the switch. So I'm sure there is nothing else.
    Here the sh running
    Core(config)# sh ru
    hostname "Core"
    ip routing
    vlan 1
    name "DEFAULT_VLAN"
    no untagged 13-14
    untagged 1-12,15-28
    exit
    vlan 100
    name "Test"
    untagged 13-14
    tagged 24
    exit
    no tftp server
    no autorun
    password manager
    It's as easy as possible
    PC1 in port 1 :
    ip : 10.70.200.101 gw : 10.70.200.11 (int address)
    PC2 in port 13 :
    ip : 10.70.201.102 gw :10.70.201.12 (the int.address)
    PC1 ping :
    it's own : ok
    to int 10.70.200.11 : ok
    to pfsense 10.70.200.254 : ok
    to other int 10.70.201.12 : nok
    to pc2 ok
    to internet : nok
    PC2 ping:
    it's own : ok
    to int 10.70.201.12 : ok
    to pfsense : nok
    to pc1 : nok
    to internet : nok
    With pc1 and gw:10.70.200.254 ----> internet ok
    for pc2 no other results
  • 15.  RE: Configure 2930f
    Posted Jun 08, 2017 06:36 AM
    Thank you very much. The switch looks fine now. From your ping results I can see it's still not correct. At least from PC1 and PC2 you must be able to ping both VLAN IP's and PC's. Could it be that you maybe have dual default GW configured on the PC's or one of them or a FW that's enabled?
  • 16.  RE: Configure 2930f
    Posted Jun 08, 2017 07:00 AM
    on your switch you are now missing the default route...
    and at the pfsense....
    you need to add a route with destination 10.70.201.0 with gateway 10.70.200.11
    and check if your PCs have the local firewall enabled
    hth...
    Alex
  • 17.  RE: Configure 2930f
    Posted Jun 08, 2017 07:07 AM
    Hi Alex,
    That's correct but pfsense is only needed when sending traffic to internet. PC to PC will go via 2930f. My feeling is also local firewall on PC's or dual default gateway or something.
  • 18.  RE: Configure 2930f
    Posted Jun 08, 2017 07:27 AM
    Hi
    here the sh ru :
    Core(config)# sh run
    hostname "Core"
    ip routing
    vlan 1
    name "DEFAULT_VLAN"
    no untagged 13-14
    untagged 1-12,15-28
    exit
    vlan 100
    name "Test"
    untagged 13-14
    tagged 24
    exit
    no tftp server
    no autorun
    password manager
    So you see the route is added.
    The only that I can say is :
    If I set the GW from PC1 to 10.70.200.11 then I can ping both interfaces and also the pc2.
    On pc2 i have echo demand for virtual machines on.
    So for the moment with this configuration I can ping from pc1 to pp2 and reverse
    With pc1 I can ping 8.8.8.8 and not with pc2.
    I will now try to add the route on my pfsense (201 to 200)
    Thx
  • 19.  RE: Configure 2930f
    Posted Jun 08, 2017 07:33 AM
    Great now we have first step done and that's the local routing on 2930f. That's working now due to fact PC's can ping each other. I can see you already added the default gateway on the switch. Indeed next step is to make sure pfsense understands the route back to vlan 100 as Alex already mentioned.
  • 20.  RE: Configure 2930f
    Posted Jun 08, 2017 08:32 AM
    I think from now on, the problem is in my pfsense i gues
    Delan009
  • 21.  RE: Configure 2930f
    Posted Jun 08, 2017 08:53 AM
    I think so. You need to create static back to VLAN 100. Hope you get all working soon. Let me know if you need any help.
  • 22.  RE: Configure 2930f
    Posted Jun 08, 2017 08:56 AM
    Thank you all for help !!!
    Delan009
  • 23.  RE: Configure 2930f
    Posted Jun 08, 2017 08:58 AM
    You're more than welcome!
    Met vriendelijke groet / Kind regards,
    [ruba-hp-signature-2_160x105.jpg]
    Dobias van Ingen
    EMEA CTO and SE Director
    UC & C: + 31202450591 | M: +31 651 785440 | @networkingdvi
    Startbaan 16 | 1187 XR Amstelveen | Netherlands
    WWW.ARUBANETWORKS.COM| FOLLOW US | Twitter | LinkedIn
  • 24.  RE: Configure 2930f
    Posted Jun 07, 2017 03:55 PM
    Hi
    Yes that is possible. I can ping to the VLAN IP's
    Delan009
