We are going to start installing AP-345s in an instant cluster and want to take advantage of the dual ports on the 345 for increased throughput. The AP will connect both cables to a 2930F 48G POE switch.
Is there any sample configs for the switch to take be able to use both ports at once on the AP 345? I read about using LACP trunks for this?
Also we will have multiple 2930F switches in the closet. Can I connect the two ports from the AP 345 to different switches for redudancy as well as throughput? If so how would I configure the LACP trunk between both switches if that is even possible?
Is there any consideration I need to know about POE on the switch and how this works using both ports on the AP 345?
Thanks for any help on this.
Dennis
