I had the same problem: I wanted to configure AAA settings on a Central managed switch: no chance through central GUI.
In the end, I used the CLI and template groups, as already mentioned.
I like the support commond.
But there is one more option: you can disable the config sync in central, per device, set the auto commit state to OFF
