Configure 3rd party SFP with 7205
  • 1.  Configure 3rd party SFP with 7205
    Posted Feb 14, 2019 11:37 AM
    Aruba OS 6.5.4.8
    7205 controller FIPS
    I am unable to get a 3rd party SFP working with the Aruba 7205. I tried the "allow-unsupported-transceivers" command, it does not appear to be valid in this OS. Below you can find the port, transceiver, and port channel information.
    Currently their are no active lights on the SFP's, on the controller.  They are active on the other end.
    I did search the forums, the user guide, and the cli reference. for information with no luck.
    Any help would be appreciated.
    Thanks.
    Any information would be appreciated.
    show interface gigabitethernet 0/0/2
    GE 0/0/2 is up, line protocol is down
    Hardware is Gigabit Ethernet, address is  (bia )
    Description: GE0/0/2 (RJ45 Connector)
    Encapsulation ARPA, loopback not set
    Configured: Duplex ( AUTO ), speed ( AUTO )
    MTU 1500 bytes, BW is 1000 Mbit
    Last clearing of "show interface" counters 1 day 0 hr 6 min 37 sec
    link status last changed 1 day 0 hr 6 min 37 sec
        0 packets input, 0 bytes
        Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
        0 input error bytes, 0 CRC, 0 frame
        0 multicast, 0 unicast
        0 packets output, 0 bytes
        0 output errors bytes, 0 deferred
        0 collisions, 0 late collisions, 0 throttles
    This port is TRUSTED
     #show interface gigabitethernet 0/0/2 transceiver
    Module is SFP
    Manufacturer        : FIBERXON INC.
    Part Number         : FTM-8012C-SL    , rev: 10
    S/N                 :
    Date Code           : 060811 Lot:
    Supported Modes     : 1000Base-SX, LC Connector
    Wavelength          : 850 nm
     #show interface port-channel 0
    Port-Channel 0 is administratively up
    Hardware is Port-Channel, address is  (bia )
    Description: Link Aggregate (LACP)
    Spanning Tree is disabled
    Switchport priority: 0
    Member port:
        GE 0/0/2, Admin is up, line protocol is down
    Last clearing of "show interface" counters 1 day 0 hr 27 min 37 sec
    link status last changed 1 day 0 hr 27 min 37 sec
    Port-Channel 0 is TRUSTED
  • 2.  RE: Configure 3rd party SFP with 7205
    Posted Feb 14, 2019 08:04 PM
    Is there a reason you have a single port associated to a part channel?
    Can you post your interface and post channel configs on both sides?
  • 3.  RE: Configure 3rd party SFP with 7205
    Posted Feb 19, 2019 10:42 AM
    The port channel was created to facilitate connectivity to two seperate vlans.   Aruba support assisted with this.
    If this is not the best procedure please let me know.
