Network Management
Configure Airwave SNMP Trap for change of status of uplink interface of IAP
  • 1.  Configure Airwave SNMP Trap for change of status of uplink interface of IAP
    Posted Apr 21, 2016 08:33 AM
    HI,
    is possible to configure on the airwave an SNMP traps when opertstate of wired IAP's interface goes down?
    In the monitor i see that one IAP ethernet interace have for admin statu  "UP" but the operation status is "Down".
    Is possible to confure an SNMP traps / Alert for this event ?
  • 2.  RE: Configure Airwave SNMP Trap for change of status of uplink interface of IAP
    Posted Apr 23, 2016 05:21 AM
    Is that AP online when this happens?  I am wondering what the true state of that AP is.  If the AP is not online, you can just set a trigger for the AP being down, otherwise, you will have to look at the trap received by Airwave and write a rule for it.
  • 3.  RE: Configure Airwave SNMP Trap for change of status of uplink interface of IAP
    Posted May 23, 2016 04:37 AM
    yes the IAP is online but it works in bridge with other AP.
    I need to know when the operational status change, how can i check it?
    Regards
    Andrea Acampa
