Do you have the RFProtect license installed and activated for all of your APs?
Did you find/follow the documentation on Wireless Intrusion Prevention?
If you check the controller and MCR logs (show log all 200), there probably is more information about why the configuration was not accepted (exception raised). Did you have a look in there already?
Original Message:
Sent: Jul 23, 2024 07:57 AM
Subject: Configure and Verify WIP
While i try to configure WIP on Aruba controller i am getting below error on ArubaOS (MODEL: Aruba7210), Version 8.10.0.12 LSR.
"Exception raised while processing request"
I also need to know how to check and verify WIP policy is on Controller.
Find below Steps to configure WIP policy
Configuration-> Task-> Define Wireless Intrusion Protection (WIP) policy.
For error message check attach screen shots.
