configure AP at different site
  • 1.  configure AP at different site
    Posted Nov 20, 2014 10:08 AM
    Is it possible to configure an ap for 1 site then ship to another site (different subnet) and just plug it in & it will be all ready to go?
  • 2.  RE: configure AP at different site
    Posted Nov 20, 2014 10:25 AM
    On your short question the short answer would be YES :)
    Though you would have to keep in mind not to configure static assignment to the virtual controller, VLANs(unless they´re the same) etc.
  • 3.  RE: configure AP at different site
    Posted Nov 20, 2014 12:46 PM
    It will depend a little on the exact configuration, but most of the time, it should work. If you?d like to share with us your intended configuration, we can review it for you.
    Yan
