Configure AP for dhcp using console cable
  • 1.  Configure AP for dhcp using console cable
    Posted Sep 14, 2012 10:20 PM
    What is the setenv command to set an ap to get an address via dhcp?
    I have some RAPs used for surveying (with static ip) and need to reprovision them to different ap-group from a hotel.  They are currently setup with static ip, so need them to boot up and get dhcp, and then hopefully they can reach the controller.
  • 2.  RE: Configure AP for dhcp using console cable
    Posted Sep 14, 2012 10:25 PM
    Think I found it. Either,
    setenv dhcp
    or
    dhcp
    :smileyhappy:
  • 3.  RE: Configure AP for dhcp using console cable
    Posted Sep 15, 2012 11:26 AM
    you do need the set command before dhcp. It can be
    set dhcp
    or
    setenv dhcp
