Configure auto generated guest passwords
  • 1.  Configure auto generated guest passwords
    Posted Nov 09, 2018 05:30 AM
    Hi there,
    we are using ArubaOS 8.3 with the integrated Guest Manager system. I was wondering if there is any way to configure how the auto gererated passwords for guests are composed. For example: I would like to use only lower or upper case letters.
    When searching for this, i only found a solution for ArubaOS 6.5 here:
    https://www.arubanetworks.com/techdocs/ClearPass/CPGuest_UG_HTML_6.5/Content/Configuration/DefaultSettingsForAccountCreation.htm
    Is it still possible to define 'password format' and 'password complexity' in ArubaOS8 or is there an other way to archive this?
    Cheers,
    Mark
  • 2.  RE: Configure auto generated guest passwords
    MVP EXPERT
    Posted Nov 09, 2018 05:47 AM
    Those options you have provided in the link are for ClearPass not ArubaOS. You would need Clearpass to achieve something like this. You can use the following via the CLI to generate accounts on a manual basis.
    (host) [mynode] #local-userdb add {generate-username|username <name>}{
    generate-password|password <password>}
  • 3.  RE: Configure auto generated guest passwords
    Posted Nov 09, 2018 07:11 AM
    Really missed that ClearPass thing .... thanks.
