Wired Intelligent Edge
Configure Interface IP on Aruba 2930F
This thread has been viewed 39 times
  • 1.  Configure Interface IP on Aruba 2930F
    Posted Apr 04, 2017 05:47 AM
    Hi, need some help on Aruba switch as this is first time using Aruba switch.
    Want to configure something like Cisco command in Aruba Switch 2030F but cant get it right...as I can only see VLAN configuration.
    Cisco(config)#interface fastEthernet 0
    Cisco(config-if)#ip address 10.199.111.41 255.255.255.0
    Or this Aruba switch does not support Interface IP for L3 purpose?
  • 2.  RE: Configure Interface IP on Aruba 2930F
    Posted Apr 04, 2017 05:52 AM
    You can only add an IP address to a VLAN. A switchport is an L2 construct.
  • 3.  RE: Configure Interface IP on Aruba 2930F
    Posted Apr 04, 2017 07:42 AM
    This is the feature in 2930F series?
    How can i find the one which allows me to define L3 interface as what Cisco switch capable of?
    I have some STP bpdu issue with Cisco switch, and would think a router port configuration would eliminate this problem.
  • 4.  RE: Configure Interface IP on Aruba 2930F
    Posted Apr 04, 2017 09:10 AM
    They are switchports. You cannot directly assign an IP address.
  • 5.  RE: Configure Interface IP on Aruba 2930F
    Posted Apr 04, 2017 11:22 AM
    In ArubaOS Switch you can´t put a physical interface in route mode.
    #You have to create an L3 vlan interface
    conf t
    interface vlan XX
      ip address 10.10.10.1 255.255.255.252
      exit
    #Then you have to untag that vlan on the interface connected to the other device
    interface 24
      untag vlan XX
    exit
  • 6.  RE: Configure Interface IP on Aruba 2930F
    Posted Apr 13, 2017 04:33 PM
    To clarify a bit on the syntax for ArubaOS-Switch: there is only one VLAN context (as opposed to the split 'VLAN' and 'VLAN interface' used by Cisco, Comware, etc); this context is used for both L3 configuration as well as assigning the VLAN to ports.
    switch# configure
    switch(config)# vlan 10
    switch(vlan-10)# ip address 172.16.0.1/16
    switch(vlan-10)# untag 1
    switch(vlan-10)# tag 24
    switch(vlan-10)# exit
    switch(config)#
