Configure L3 Mobility
  • 1.  Configure L3 Mobility
    Posted Mar 27, 2014 12:31 PM
    I want to implement L3 mobility between 2 cluster iap 93
    can you give me the configuration ?
    As an attachment there is a diagram of my installation and configuration page
  • 2.  RE: Configure L3 Mobility
    Posted Mar 27, 2014 12:41 PM
    Download a copy of the IAP v.4.0 Users Guide.  Chapter 16 - Mobility and Client Management cover the configuration in detail.
    At a high-level you need to point the VC's in each subnet to the other VC's similar in concept to doing static routing.   They should have statically assigned VC IP addresses.
  • 3.  RE: Configure L3 Mobility
    Posted Mar 27, 2014 12:57 PM
    Thank you for your answer.
    So in the first table I get the IP address of the virtual controller of each cluster (192.168.100.1 and 192.168.200.1).
    But in the second, I do not understand what to enter ??
  • 4.  RE: Configure L3 Mobility
    Posted Mar 27, 2014 01:19 PM
    For the second box you list the subnet of VC 1 and the subnet of VC 2.
    Here is a tutorial I put together a while ago.  It is on an older version of SW so the screens may look a little different:
  • 5.  RE: Configure L3 Mobility
    Posted Oct 25, 2017 01:31 PM
    In your example, is it necessary to input the VC IP addresses and subnet settings on all VCs on the "campus", or just set them in the one you want to be the main L3 mobility controller?
