Configure LACP for the Wireless AP
  • 1.  Configure LACP for the Wireless AP
    Posted Aug 24, 2019 09:44 AM
    Dear All
    Can I configure the wireless AP port for the LACP to the PoE Switch. If Yes please guidance and I new in Aruba AP.
    Controller Firmware: ArubaOS 8.3.0.6
    AP Model: Aruba 345
  • 2.  RE: Configure LACP for the Wireless AP
    Posted Aug 24, 2019 11:00 AM
    Configure the switch ports to Lacp trunk and connect both cables to the ap. The AP knows when booting there is a lacp trunk. I think you can also config it manual but I think this is mutch easyer
  • 3.  RE: Configure LACP for the Wireless AP
    Posted Aug 24, 2019 11:20 AM
    Hi Expert
    Thanks for the explanation and how should I verify the LACP Trunk on the AP side.
  • 4.  RE: Configure LACP for the Wireless AP
