Cloud Managed Networks
Configure NTP in switches with Central
  • 1.  Configure NTP in switches with Central
    Posted Mar 12, 2020 02:27 PM
    Hi, does anyone know if is it possible to configure NTP in a 2930F switch that is managed by Central?
    I cannot find that setting anywhere for switches.
  • 2.  RE: Configure NTP in switches with Central
    Posted Apr 05, 2020 08:39 PM
    you can do it through the WebUI in Aruba central.
    once you are in settings use the system tab and then time
    your options are Time Sync Method =SNTP
    and if you choose the mode as unicaste then you can add the NTP server
    https://help.central.arubanetworks.com/2.5.0/documentation/online_help/content/switches/cfg/conf-time-sync-method.htm?Highlight=time%20sync%20method
