Configure SSH
This thread has been viewed 26 times
  • 1.  Configure SSH
    Posted May 15, 2014 04:16 PM
    Can someone tell me the CLI commands to enable SSH and set the password in a aruba controller running 6.3.1.4
    Thank you,
  • 2.  RE: Configure SSH
    Posted May 15, 2014 04:17 PM
    It is enabled by default. Set credentials using the mgmt-user command.
  • 3.  RE: Configure SSH
    Posted May 15, 2014 04:23 PM
    Thanks for your help. Can you also help me distiguish between the web UI login and SSH or are they the same?
    Also, commands to configure telnet.
    Thank you,
  • 4.  RE: Configure SSH
    Posted May 15, 2014 04:31 PM
    The "mgmt-user" accounts are the same for the CLI and the WebUI.
    To enable telnet, use "telnet cli".
    Best regards,
    Madani
  • 5.  RE: Configure SSH
    Posted May 15, 2014 04:18 PM
    Mark,
    SSH is enabled by default unless you have an ACL in place to block it.
    To create a user, use the "mgmt-user" commands.
    Best regards,
    Madani
