Configure Time Manually on IAP 93
  • 1.  Configure Time Manually on IAP 93
    Posted Sep 06, 2012 05:09 AM
    can you guys help me out in configuring Time and date manually on my IAP 93 because i put NTP server and time zone and time is not right its 2001 !! My NTP server is pool.ntp.org
  • 2.  RE: Configure Time Manually on IAP 93
    Posted Sep 06, 2012 07:06 AM
    Do it from the commandline and SSH or telnet into the IAP:
    00:24:6c:ca:cb:b0# clock ?
    set Set the time and date
    00:24:6c:ca:cb:b0# clock set ?
    <year>     Year
    00:24:6c:ca:cb:b0# clock set 2012 ?
    <month>     Month
    00:24:6c:ca:cb:b0# clock set 2012 9 6 ?
    <hour>     Hour
    00:24:6c:ca:cb:b0# clock set 2012 9 6 6 ?
    <min>     Minutes
    00:24:6c:ca:cb:b0# clock set 2012 9 6 6 4 ?
    <sec>     Seconds
  • 3.  RE: Configure Time Manually on IAP 93
    Posted Sep 06, 2012 10:03 AM
    thx for your reply but i think the VC refused the connection through Telnet and SSh gives me this is there an option at the UI to open Telnet?!!
    Connecting To 172.27.2.57...Could not open connection to the host, on port 23: Connect failed
  • 4.  RE: Configure Time Manually on IAP 93
    Posted Sep 06, 2012 10:49 AM
    In order to enable telnet on the iAP,
    1. log into the webUI of the VC
    2. click on "Settings"
    3. Click on "Show advanced options"
    4. Under the "General" tab on the RHS you will see an option "Terminal Access"
    5. Click on the drop down and select "Enabled"
    6. click OK.
  • 5.  RE: Configure Time Manually on IAP 93
    Posted Sep 06, 2012 12:32 PM
    Thank you very Much all done now
