We have just purchased AP-103H and is working on the configurations. How can we configure the following scenario? Please advise.
sohpiechan
Do you mean the wired AP profile in the ap-group?
sophiechan
Is this setting correct? Which vlan does the AP request for DHCP IP when the uplink is a trunk?
Yes, that looks correct. The AP will use the native VLAN.
Is this setting correct for eth1? We want to connect a PC to it and put it in vlan 21.
Many thanks.
We do not want authentication on eth1, just want to switch all the traffic to vlan21.
Thanks a lot. We tested the setup today.
Dear,
Could you please tell me how can I disable the lower 2 ports on the 103H, which they are E1 and E2 because we will not use them, so I need them to be shutdowned.
Note that I need to keep the E0 working.
