Configure Wired Guest Network Access with an OmniSwitch and ClearPass Guest
  • 1.  Configure Wired Guest Network Access with an OmniSwitch and ClearPass Guest
    Posted Dec 17, 2014 06:22 PM
    Hi Team:
    I can configure ClearPass Guest with an OmniSwitch Alcatel Lucent. I configured web login and have message error:
    My configured ClearPass is following with an service Web Authentication:
    What would it could be the error?
  • 2.  RE: Configure Wired Guest Network Access with an OmniSwitch and ClearPass Guest
    Posted Dec 17, 2014 06:24 PM
    That usually means the MAC address is not being sent in the URL redirect. Can you confirm that?
  • 3.  RE: Configure Wired Guest Network Access with an OmniSwitch and ClearPass Guest
    Posted Dec 17, 2014 06:29 PM
    I send url redirect for authentication mac. The portal login authenticate with me Guest Repository (Service -- Authentication -- Guest Repository)
    Example: https://www.youtube.com/watch?v=gVUUE59ptPI
  • 4.  RE: Configure Wired Guest Network Access with an OmniSwitch and ClearPass Guest
    Posted Dec 17, 2014 06:32 PM
    Try adding the following to the end of the URL in your enforcement profile:
    ?%{Connection:Client-Mac-Address}
  • 5.  RE: Configure Wired Guest Network Access with an OmniSwitch and ClearPass Guest
    Posted Dec 17, 2014 06:36 PM
    If I tried it also with no success. I have to consider something in the configuration of the Switch?
  • 6.  RE: Configure Wired Guest Network Access with an OmniSwitch and ClearPass Guest
    Posted Dec 17, 2014 06:40 PM
    Try creating a webauth service
  • 7.  RE: Configure Wired Guest Network Access with an OmniSwitch and ClearPass Guest
    Posted Dec 18, 2014 06:19 PM
    Hi Team:
    The solutions is the following.
    Thanks you
  • 8.  RE: Configure Wired Guest Network Access with an OmniSwitch and ClearPass Guest
    Posted Dec 18, 2014 06:31 PM
    Thank you for the follow up...
  • 9.  RE: Configure Wired Guest Network Access with an OmniSwitch and ClearPass Guest
    What do you use in the Access Tracker ?
    Do you have a webauth service?
