Did you apply the licenses the MM and AP licenses ?
Can you see the AP up?
Verify that the SSID and virtual-AP profile are enabled and you have a AAA profile assigned under the virtual AP
From the controller CLI you can run the following :
- show ap active
- show AP essid (check if SSID is being broadcasted on the MC)
Thank you
Victor Fabian
Pardon typos sent from Mobile
