Wired Intelligent Edge
configuring 2540 as L2 switch to work with 2930f as L3 core switch
  • 1.  configuring 2540 as L2 switch to work with 2930f as L3 core switch
    Posted May 16, 2018 05:45 AM
    Hi folks, I'm very new to Aruba switches so would appreciate some pointers on how to configure my network.
    I have a 2930f and a 2540.  I've configured my 2930f as L3, with intervlan routing and point-to-point connection to the firewall, and reverse route from firewall back to the 2930f for all the corresponding subnets.  Everything is working fine.
    I am now scratching my head on how to configure the 2540 as L2 only.
    My understanding (based on what I've read) is to NOT use the default VLAN (i'll remove ports associated with VID 1 on the 2930f as i continue the config).
    Further, since all routing should be done by the 2930f, is it correct to configure all the VLANs on the 2540 with no ip address and no ip routes?
    And now i'm trying to figure out how to configure the 2540's management to be on VLAN 100, and still can be access throughout the network, when no ip routes and ip address are associated with the VLANs on the 2540.
    Any guidances will be much appreciated.  Below is the config for my 2930f.  Thanks.
    Startup configuration: 48
    ; JL254A Configuration Editor; Created on release #WC.16.05.0007
    ; Ver #12:08.1d.9b.3f.bf.bb.ef.7c.59.fc.6b.fb.9f.fc.ff.ff.37.ef:ba
    hostname "2930-1"
    module 1 type jl254a
    timesync ntp
    no sntp
    ntp unicast
    ntp server 216.239.35.12 iburst
    ntp enable
    time timezone 480
    ip default-gateway 10.81.6.1
    ip route 0.0.0.0 0.0.0.0 10.81.6.1
    ip route 10.81.10.0 255.255.255.0 vlan 100
    ip routing
    snmp-server community "public" unrestricted
    vlan 1
       name "DEFAULT_VLAN"
       no untagged 25-29,36,39-40,48
       untagged 1-24,30-35,37-38,41-47,49-52
       ip address 10.81.0.1 255.255.255.0
       exit
    vlan 60
       name "Firewall_VLAN"
       untagged 48
       ip address 10.81.6.2 255.255.255.0
       exit
    vlan 100
       name "Mgmt_VLAN"
       untagged 25-29,36
       tagged 45
       ip address 10.81.10.1 255.255.255.0
       exit
    vlan 160
       name "Printers_VLAN"
       tagged 45
       ip address 10.81.16.1 255.255.255.0
       exit
    vlan 200
       name "Wired_Data_VLAN"
       untagged 40
       tagged 45
       ip address 10.81.20.1 255.255.255.0
       dhcp-server
       exit
    vlan 440
       name "DVR_VLAN"
       tagged 45
       ip address 10.81.44.1 255.255.255.0
       exit
    vlan 600
       name "Voice_VLAN"
       tagged 45
       ip address 10.81.60.1 255.255.255.0
       voice
       exit
    vlan 999
       name "FortiGate_VLAN"
       untagged 39
       ip address 192.168.0.222 255.255.255.0
       exit
    no tftp server
    no autorun
    no dhcp config-file-update
    no dhcp image-file-update
    dhcp-server pool "wired-data-static"
       authoritative
       default-router "10.81.20.1"
       dns-server "8.8.8.8"
       lease infinite
       static-bind ip 10.81.20.68 255.255.255.0 mac 00051b-a28ee4
       exit
    dhcp-server enable
    password manager
    password operator
  • 2.  RE: configuring 2540 as L2 switch to work with 2930f as L3 core switch
    Posted May 16, 2018 02:14 PM
    Greetings!
    If you want your 2540 to be L2-only — with the exception of the management VLAN — you would configure your VLANs as you suggested, with no IP addresses or associated routes, and have them be tagged on the uplink to the 2930F.
    The management VLAN itself would have an IP address (and a gateway, if your management stations are on a different subnets); it can even use the same uplink port as the rest of the VLANs without causing issues.  Note that you do not need to enable IP routing on the 2540 itself, as it would not be performing any inter-VLAN routing (this occurs on the 2930F, as intended).
    You would also want to apply appropriate security configuration to limit access to authorized users, using the ArubaOS-Switch Hardening Guide as a reference.
  • 3.  RE: configuring 2540 as L2 switch to work with 2930f as L3 core switch
    Posted May 17, 2018 03:58 AM
    Thanks Matthew, much appreciated!
