Configuring a point to point Mesh link in Aruba Central
This thread has been viewed 16 times
  • 1.  Configuring a point to point Mesh link in Aruba Central
    Posted May 22, 2018 12:47 PM
    Hello
    I have tested a p2p mesh link between an IAP 305 and 303H using Aruba Central.
    Internet -> Switich -> IAP305 ---- Mesh Link ---- AP303H --- Client
    Here is the step by step guide:
    1. Connect both APs to the same L2 network (same VLAN):central Mesh 1.png
    2. Upgrade firmware to recommended release:
    3. Disable "Extended SSID":
    4.  Disconnect the AP 303H and wait 5 minutes, AP will connect via Mesh.  Mesh, by default within IAP, will share the 5Ghz for backhaul and client access.
    Central Mesh 5.png5. Test WiFi, it works!
    Adolfo
