Configuring Airgroup on instant
  • 1.  Configuring Airgroup on instant
    Posted Nov 24, 2015 05:18 PM
    We have about a dozen 225 APs.   We have about 200 employees.   80% of our employees have airbooks and iphones.   I was watching a video recommending airgroup.   Not sure if I need to buy a module or not.   I have no idea what settings I should check or uncheck.
    They use airplay and use wireless printing and just about anything google for storage and apps.
    #AP225
  • 2.  RE: Configuring Airgroup on instant
    Posted Nov 24, 2015 05:20 PM
    Enable bonjour and DLNA at the top. Then I would check airgroup, airplay, googlecast, dial and the DLNA options.
    Sent from Nine
  • 3.  RE: Configuring Airgroup on instant
    Posted Nov 24, 2015 05:45 PM
    Thanks - I'll do that.    Do I need to know anything about clearpass?
  • 4.  RE: Configuring Airgroup on instant
    Posted Nov 24, 2015 05:52 PM
    You only need to. configure ClearPass if you want to add registration/policy control.
    Sent from Nine
  • 5.  RE: Configuring Airgroup on instant
    Posted Apr 05, 2016 06:39 PM
    If I were trying to figur out Airprint and stumbled onto this thread, would I also need to put a helper on the gateway router for the wireless VLAN to get the airprint traffic over to the wired VLAN, or will the iAP help with that bit?
    (I'm a Linux/Andriod user trying to figure out an iThing concept - forgive the possibly misguided nature of my question)
