Configuring an AP135 as an RAP
  • 1.  Configuring an AP135 as an RAP
    Posted Nov 27, 2014 02:52 PM
    Currently the network I manage has as many AP's as it does RAP'S. We had a power issue last night where as 3 of our RAP-155 got shorted out.
    These locations needs a RAP and I dont have anymore in stock. All I have are some RAP-5WN but becasue of my controllers version they wont take the upgrade.
    I have configured an AP135 as a remote AP for the time being. Wireless is braodcasting fine but there are some devices that require a hardline.
    Question is there a way to enable ETH1 on the AP135 to issue DHCP from the contoller as ETH0 is currrently the uplink or some work-around to this issue until I can receive some more RAP-155.
    Controllers are all 3600's running Version 6.3.1.8.
    Thanks in advance for any and all responses.
    #3600
  • 2.  RE: Configuring an AP135 as an RAP
    Posted Nov 27, 2014 05:16 PM
    Change the wired port profile for Ethernet 1
  • 3.  RE: Configuring an AP135 as an RAP
    Posted Dec 01, 2014 01:38 PM
    It is very easy to configure e1 port of AP135, follow the steps bellow.
    we need to configure Wired AP profile under AP--> wired-ap
    use the following commands to configure the profile,
    ap wired-ap-profile <profile-name>
    forward-mode bridge
    wired-ap-enable
    Optionally, you can configure the following wired AP profile settings:
    switchport mode {access | trunk}
    switchport access vlan <vlan>
    switchport trunk native vlan <vlan>
    switchport trunk allowed vlan <vlan>
    trusted
    After this map the profile to AP--Wired AP by using the following command.
    (Aruba3200) (config) #ap wired-ap-profile <profile-name>
    Hope your issue can be resolved now :)
    Cheers,
    Venu
  • 4.  RE: Configuring an AP135 as an RAP
    Posted Dec 04, 2014 10:49 AM
    Thanks for the information. I made the changes and now able to connect on the secondary port.
