Configuring AP-325
This thread has been viewed 37 times
  • 1.  Configuring AP-325
    Posted Aug 01, 2017 11:56 AM
    I am setting up a whole new IT infrastructure for a company and I got two Aruba AP-325.
    I have never worked with those access points and I first thought it would have been really easy to configure.
    But from where do I start? How do I configure it for the first time? Can I access a web interface?
    Thanks a lot if any body can give me an answer it would be wonderful.
  • 2.  RE: Configuring AP-325
    Posted Aug 01, 2017 12:19 PM
    Are those AP-325s or IAP-325s?  Read the sticker on the back if you can...
  • 3.  RE: Configuring AP-325
    Posted Aug 01, 2017 12:25 PM
    I think it's a simple AP-325 and not IAP. Thank you
  • 4.  RE: Configuring AP-325
    Posted Aug 01, 2017 12:32 PM
    AP 325s require an Aruba contrik
  • 5.  RE: Configuring AP-325
    Posted Aug 03, 2017 04:40 AM
    So I so today, it is written : APIN0325
    How can I configure it? Does it require anything special?
    Thank you for your help
  • 6.  RE: Configuring AP-325
    MVP EXPERT
    Posted Aug 03, 2017 05:31 AM
  • 7.  RE: Configuring AP-325
    Posted Aug 03, 2017 05:39 AM
    Thank you,
    I am trying to get this right, do I need the controller? Is it necessary?
    Right now, I have an Aruba Switch 48p and I don't have anything configured for the Wifi. I only have two HP Aruba AP-325 as mentionned earlier.
    How can I get them to work?
    Thanks a lot+
  • 8.  RE: Configuring AP-325
    MVP EXPERT
    Posted Aug 03, 2017 05:41 AM
    Look at the back of the AP and check the model number it will be AP or IAP.
    If you have AP-xx then you will need a physical controller.
    If you have IAP-xx then you can configure the Virtual Controller using the instructions provided earlier.
