version 8.4.0.0-8.4.0
virtual-controller-country US
virtual-controller-key
name Robo-BN-Mesh
terminal-access
clock timezone none 00 00
rf-band all
allow-new-aps
allowed-ap 90:4c:81:c0:27:fe
allowed-ap 90:4c:81:c0:28:4c
arm
wide-bands 5ghz
80mhz-support
a-channels 116E
min-tx-power 9
max-tx-power 127
band-steering-mode prefer-5ghz
air-time-fairness-mode default-access
channel-quality-aware-arm-disable
client-aware
scanning
rf dot11g-radio-profile
max-distance 0
max-tx-power 9
min-tx-power 6
disable-arm-wids-functions off
free-channel-index 40
rf dot11a-radio-profile
max-distance 0
max-tx-power 18
min-tx-power 12
syslog-level warn ap-debug
syslog-level warn network
syslog-level warn security
syslog-level warn system
syslog-level warn user
syslog-level warn user-debug
syslog-level warn wireless
extended-ssid
wlan access-rule BR
index 0
rule any any match any any any permit
wlan access-rule default_wired_port_profile
index 1
wlan access-rule wired-SetMeUp
index 2
rule masterip 0.0.0.0 match tcp 80 80 permit
rule masterip 0.0.0.0 match tcp 4343 4343 permit
rule any any match udp 67 68 permit
rule any any match udp 53 53 permit
wlan access-rule Wired-Trunk-Port
index 3
wlan ssid-profile BR
enable
index 0
type employee
essid BNR
wpa-passphrase
opmode wpa2-psk-aes
max-authentication-failures 0
rf-band all
captive-portal disable
dtim-period 1
broadcast-filter arp
dmo-channel-utilization-threshold 90
local-probe-req-thresh 0
max-clients-threshold 64
enet-vlan 400
auth-survivability cache-time-out 24
wlan external-captive-portal
server localhost
port 80
url "/"
auth-text "Authenticated"
auto-whitelist-disable
https
blacklist-time 3600
auth-failure-blacklist-time 3600
ids
wireless-containment none
wired-port-profile wired-SetMeUp
switchport-mode access
allowed-vlan all
native-vlan guest
no shutdown
access-rule-name wired-SetMeUp
speed auto
duplex auto
no poe
type guest
no dot1x
wired-port-profile default_wired_port_profile
switchport-mode trunk
allowed-vlan all
native-vlan 1
shutdown
access-rule-name default_wired_port_profile
speed auto
duplex full
no poe
type employee
no dot1x
wired-port-profile Wired-Trunk-Port
allowed-vlan all
native-vlan 400
no shutdown
access-rule-name Wired-Trunk-Port
speed auto
duplex auto
no poe
type employee
auth-server InternalServer
no dot1x
enet0-port-profile Wired-Trunk-Port
enet1-port-profile Wired-Trunk-Port
uplink
preemption
enforce none
failover-internet-pkt-lost-cnt 10
failover-internet-pkt-send-freq 30
failover-vpn-timeout 180
airgroup
disable
airgroupservice airplay
disable
description AirPlay
airgroupservice airprint
disable
description AirPrint
cluster-security
allow-low-assurance-devices
