Hi there,
I've got two stacks of 2x2930M and I configured LAG between them as the follow (each switch got HPE 4-Port SPF+ module):
for first stack : trunk 1/A1,2/A1 trk1 lacp
for the second stack : trunk 1/A1,2/A1 trk1 lacp
Now I've added 10G SPF+ on each switch and I need them to be added the LAG above, so what's the correct command for that ?
Shall I delete the trk1 above and recreate it with following :
trunk 1A1,2A1,1A2,2A2 trk1 lacp ( and the same command on other stack switches), or just simply add the new interface to the existing LAG with
trunk 1A2,2A2 trk1 lacp ?
thanks
Adam Black
