Cloud Managed Networks
Configuring manual cluster
  • 1.  Configuring manual cluster
    Posted Mar 20, 2024 07:25 PM
    Hello guys I'm in a situation in which I need to configure a manual cluster because will be using g CoA and also microbranch
    I have never done this before because I have configured it but with the automatic cluster.
    • On the group level, I go and turn the auto cluster off
    • Click plus on clusters
    • Put a name of the cluster
    • check for coa and VPN termination for microbranch (ill have a remote ap so I guess the microbranch will work for that? the clients used to have some remote APs and we need to configure this)
    • The vrrp vlan could be the system vlan??
    • The vrrp IP is the Virtual IP address in which in my case ill add that one to Clearpass as NAD?
    • Do I need to fill ID and passphrase field?
    • Guess I will do this config at the group level.
    • Do I need to configure anything on the redundancy tab? or that's all? if not when do I need to configure something there?
  • 2.  RE: Configuring manual cluster
    Posted Mar 22, 2024 09:16 AM
    Anyone?
