We've got a cluster of controllers (aruba0, arubal1 - arubal4) that are running ArubaOS 6.4.3.6. As normal, our RADIUS server configurations a rereplicated from the master controller down to all the local ones. Looking in my RADIUS accounting logs, I can see that the nas-ip-address matches up with the IP address of the controller sending rthe RADIUS auth request. However the nas identifier is always that of the master controller. This is correct because on aruba0 I've set the nas identifier to be "aruba0" and this gets pushed to all the other controllers. If I log onto a local controller , I can;t modify the nasidentifier as seen in a RADIUS server configuration because its read only. Is there any way of getting each local controller to advertise its own name as the nasidentifier instead of that of the master controller?
