Configuring Onboard on CPPM 6.1
  • 1.  Configuring Onboard on CPPM 6.1
    Posted May 29, 2013 07:22 PM
    Im looking for documentation on how to configure Onboard on CPPM 6.1. The online help seems to point to 6.0.2 screens.
    Any pointers much appreciated.
  • 2.  RE: Configuring Onboard on CPPM 6.1
    Posted May 29, 2013 07:28 PM
    They are currenly being worked on. They will be published to the support site when they are done.
    http://support.arubanetworks.com/DOCUMENTATION/tabid/77/DMXModule/512/EntryId/7961/Default.aspx
    The only major differences
    1. you now have the option to do mulitple CAs
    2. the web login page is built into the provisioning settings.
  • 3.  RE: Configuring Onboard on CPPM 6.1
    Posted May 29, 2013 08:19 PM
    Thanks for the pointer..
    how does one configure an existing enterprise PKI server as a CA server for CPPM. What mode do I need to select?
    thanks
  • 4.  RE: Configuring Onboard on CPPM 6.1
    Posted May 30, 2013 12:57 AM
    If CPPM will generate and hand out certs based off of your existing PKI you would select intermediate. Once you fill in the information it will generate a CSR for you to sign by your PKI CA and then import it back into CPGuest and now you can hand out certs based on your own PKI.
