Configuring QOS for Microsoft Teams - Aruba Mobility Controller
This thread has been viewed 57 times
  • 1.  Configuring QOS for Microsoft Teams - Aruba Mobility Controller
    Posted Apr 15, 2020 07:10 PM
    I need some assistance configuring QOS for Microsoft Teams. I was able to configure it successfully for the wired networks on the Aruba Switches; however, I need assistance with configuring them on the Wireless Controller.
    Currently using Aruba Mobility Controller:
    Version: ArubaMC-VA-US 8.5.0.2
    Microsoft Teams is configured in the O365 admin center to use:
    Voice: TCP Ports 50000-50019 DSCP 46 (Expedited Forwarding)
    Video: TCP Ports 50020-50039 DSCP 34 (Assured Forwarding)
    So far, I followed the documentation here:
    https://www.arubanetworks.com/techdocs/ArubaOS_81_Web_Help/Content/ArubaFrameStyles/Voice_Video/QoS_for_Voice_and_Video.htm
    I have the commands:
    wlan ssid-profile default
      wmm
      wmm-vo-dscp 46
      wmm-vi-dscp 34
    However, it says to use ip access-list session? How do I configure Microsoft Teams which uses ports 50000 - 50019 to be marked as DSCP 46 on the Wireless?
    I was trying to use:
    ip access-list session VOICE
    any any tcp source 50000 permit dot1p-priority 7
    It does not let me specify a range of ports; it only lets me specify 1 port at a time. Also is this even the correct command?
    Any help would be greatly appreciated.
    End goal whichever method is used: QOS should be enabled for Microsoft Teams for Wireless devices using ports 50000-50019 for voice and 50020-50039 for video.
    Thank you.
  • 2.  RE: Configuring QOS for Microsoft Teams - Aruba Mobility Controller
    Posted May 05, 2020 09:09 AM
    Did you ever get any response on this?  We are having same issue and wanted to know.  Just opened a cased with support
  • 3.  RE: Configuring QOS for Microsoft Teams - Aruba Mobility Controller
    Posted May 06, 2020 08:43 AM
    Spoke with support yesterday and they made the following changes to our controller and we are monitoring now:
    • Enabled WMM on our SSID
    • Unable to see HTPV during a test using DSCP voice 56 and video 40
    • Changed DSCP voice to 46 and video to 34 which matched the pre-configured DSCP for Skype4B
    • Tested again and we saw the HPTV flags as well as the ports being used by the Teams meeting.
    • Monitoring for uses going forward
    Do a show wlan ssid-profile <SSID> and you will see WMM DSCP Mapping control then do a show datapath session table <IP Address of client> | Included <IP Address of other party>
    Hope this helps.
  • 4.  RE: Configuring QOS for Microsoft Teams - Aruba Mobility Controller
    Posted Jun 02, 2020 11:19 AM
    Could you share any info on how you did this on the wired side? I am new to QOS and before 3 months ago I could count on 1 hand the amount of people that used teams in the company. Now everyone is using it and we are starting to get jitter when there are more than 2-3 people in a group.
    5706r core fibre connected to 6 cisco 3750g switches
  • 5.  RE: Configuring QOS for Microsoft Teams - Aruba Mobility Controller
    Posted Jun 02, 2020 11:23 AM
    We followed this GPO guide from Microsoft which marked the packets for us.  Since we are already a VOIP campus, we had the DSCP set up on the switches already.
    https://docs.microsoft.com/en-us/microsoftteams/qos-in-teams-clients
