Network Management
Configuring SNMP with errors
  • 1.  Configuring SNMP with errors
    Posted Sep 18, 2018 04:34 AM
    Hi! I am configuring SNMP in an aruba switch 5412R, and I dont get to make it works. I have been troubleshooting and I got the attached results. Does anyone know which is the problem?
  • 2.  RE: Configuring SNMP with errors
    Posted Sep 18, 2018 09:08 AM
    this looks like you try to read a Cisco specifig value from your HPE/Aruba switch.
    Only general (standard mib) values and HPE/Aruba specific values are available on these switches ;-)
    Regards, Jörg
  • 3.  RE: Configuring SNMP with errors
    Posted Sep 19, 2018 03:56 AM
    Yes it was a smaal part of the problem, but the real problem was that we havent access to the switch because of the lack of the
    snmp-server response-source dst-ip-request-source command.
    Entering that command have let us to have access to the equipment and using the new MIB.
    Thanks Jorg!
  • 4.  RE: Configuring SNMP with errors
    Posted Sep 19, 2018 07:53 AM
    Can you share some more logs
