Wired Intelligent Edge
Configuring vlan ports
  • 1.  Configuring vlan ports
    Posted Jul 25, 2020 11:13 PM
    Still getting used to working with Aruba switches. I want to create another vlan. I didn't configure the switches originally, but, the vlan I need to create is similar to vlan 9 in the attached image. It has Trk1 tagged. I'm not sure how to add Trk1 to vlan 16. I tried through the web ui, but when I add Trk1 as tagged and hit Save, it tells me there were no changes. Also, the previous vlans have ipv6 disabled. In the web ui I tried to disable ipv6 in vlan 16, but after I save it, it still shows. Thank you for your help.
  • 2.  RE: Configuring vlan ports
    MVP GURU
    Posted Jul 26, 2020 06:45 PM
    Hi! please get used to work with CLI (Web based interface is mostly to show you some settings instead of permitting you to modify them).
    @mg14 wrote:  the vlan I need to create is similar to vlan 9 in the attached image. It has Trk1 tagged.
    VLAN 9 exists and logical interface Trk1 (aggregation of some physical ports) was made tagged member of that VLAN id.
    To create a new VLAN - say you need VLAN id 16 - use the CLI command (config mode):
    vlan 16
    name <place-a-descripiton-of-this-vlan-here>
    exit
    it enters you in the VLAN 16 context (from which you can exit with the command exit).
    To tag Trk1 with VLAN 16, inside the VLAN 16 context simply:
    vlan 16
    tagged trk1
    exit
    write memory (to save)
    Done.
    The point is: you will need also some access ports as untagged members of that new VLAN, isn't it? otherwise why transport it over the Trk1 interface?
    To see the VLANs membership of a particular physical port/logical interface use:
    show vlan port <port-id>/<trk-id> details
  • 3.  RE: Configuring vlan ports
    Posted Jul 26, 2020 08:33 PM
    I'm working through web based and CLI to get used to the settings and commands. Used 3com switches for years and just recently made a transition to Aruba. I've got some of the commands down that I need, but then run into some issues along the way. Thank you for your help, appreciate it.
  • 4.  RE: Configuring vlan ports
    MVP GURU
    Posted Jul 27, 2020 05:22 AM
    Hi! glad you're familiarizing with ArubaOS-Switch CLI (an enhanced/developed HP ProVision CLI).
    @mg14 wrote: I've got some of the commands down that I need, but then run into some issues along the way. Thank you for your help, appreciate it.
    What issues exactly?
  • 5.  RE: Configuring vlan ports
    Posted Jul 29, 2020 07:17 PM
    Just getting used to commands. Stuck on the ipv6 disabling now. The person that setup the switches disabled ipv6 on each vlan. I created two vlans and ipv6 is enabled and I can't figure out how to disable ipv6 on the two vlans.
  • 6.  RE: Configuring vlan ports
    Posted Jul 30, 2020 02:26 AM
    Type "no ipv6 enable" in required VLANs (through CLI)
  • 7.  RE: Configuring vlan ports
    Posted Jul 30, 2020 07:32 AM
    Appreciate everyone's help with my questions.
