last person joined: 11 hours ago
Configuring Wired Ports in Aruba OS 8.2.0.1
  • 1.  Configuring Wired Ports in Aruba OS 8.2.0.1
    Posted Apr 04, 2018 05:59 PM
    Greetings,
    I am trying to configure the wired ports on an AP 205H. How is this accomplished in version 8? Does it have to be done CLI? How do you associate an AP Wired Port profile to an AP Group or AP? The documentation indicates you need to associate the AP Wired Port profile to a AAA profile? How is this done???
    Thanks!
  • 2.  RE: Configuring Wired Ports in Aruba OS 8.2.0.1
    Posted Apr 04, 2018 06:25 PM
    You should be able to do this via GUI or CLI
    For GUI you can go to
    "Configuration > System > AP > AP Wired AP" and to configure the port for
    either access or trunk then go here "Configuration > System > AP > Wired
    AP" and then assign it under the AP Wired AP
    Once you have configure it , you can go to the AP-Group and assign it
    directly to the eth AP port
  • 3.  RE: Configuring Wired Ports in Aruba OS 8.2.0.1
    Posted Apr 04, 2018 09:30 PM
    I'm also curious about this. In 8.x, it seems you can only configure 1 port profile that would apply to all ports. In 6.x there was a enet0,1,2,n profile section for each respective port.
  • 4.  RE: Configuring Wired Ports in Aruba OS 8.2.0.1
    Posted Apr 04, 2018 09:38 PM
    No , that is not correct ..you can configure it the same way as before
  • 5.  RE: Configuring Wired Ports in Aruba OS 8.2.0.1
    Posted Apr 04, 2018 09:42 PM
    Can you elaborate? When I configure each wired port profile, how do I specify which port it applies to?
  • 6.  RE: Configuring Wired Ports in Aruba OS 8.2.0.1
    Posted Apr 05, 2018 09:26 AM
    Once you create the different Wired Ports you need , you can go to the
    AP-Group > Profiles > AP and then assign it to the correct eth port.
    Make sure that you have enabled Advanced View under your login profile
    (right hand corner), otherwise you wont be able to see the Profiles option
  • 7.  RE: Configuring Wired Ports in Aruba OS 8.2.0.1
    Posted Apr 05, 2018 12:05 PM
    Oh Ok I see. I was not aware of the advanced view!
  • 8.  RE: Configuring Wired Ports in Aruba OS 8.2.0.1
    Posted Apr 05, 2018 03:44 PM
    "Advanced Profiles", had no idea. Now this all makes sense! Thank you!
