Configuring WPA3-Enterprise
This thread has been viewed 37 times
  • 1.  Configuring WPA3-Enterprise
    Posted Jun 21, 2022 06:18 AM
    We want to test various WPA3 opmodes, including wpa3-aes-ccm-128. My devices connect fine when I change our test SSID to this (using PEAP/MSCHAPv2) but they show the SSID as being WPA/WPA2 not WPA3 when I look at the network details. I was using an AP-314 and now an AP-635. Is there a way to check on the controllers what opmode ArubaOS thinks my clients are using?
    I have Opmode transition disabled so I was assuming the clients would have to use WPA3 or not be able to connect? (I'm not sure which of them I would expect to support WPA3, my laptop is definitely old enough that it might be borderline, but my MacBook and Pixel are pretty recent).
    Thank you,
    Guy
  • 2.  RE: Configuring WPA3-Enterprise
    Posted Jun 21, 2022 07:34 AM
    show dot1x supplicant-info list-all
  • 3.  RE: Configuring WPA3-Enterprise
    Posted Jun 21, 2022 07:46 AM
    Great thanks Colin, so I get:
    (UWS-MC-A1-DEV) #show dot1x supplicant-info list-all
    802.1x User Information
    MAC Name Auth AP-MAC Enc-Key/Type Auth-Mode EAP-Type Remote
    f8:0f:f9:dd:1a:d9 xxx@xxx.xx.xx Yes 94:64:24:92:6c:f1 * * * * * * * */WPA3-AES-GCMP-256-NON-CNSA Explict Mode EAP-PEAP No
    So that looks good to me. I wonder why the devices don't report that, anyway it's reassuring that it does look like they are using WPA3, must be something missing/incorrect in the packet exchange I suppose.
  • 4.  RE: Configuring WPA3-Enterprise
    Posted Jun 21, 2022 07:51 AM
    Which device(s) and how are they reporting it?
  • 5.  RE: Configuring WPA3-Enterprise
    Posted Jun 22, 2022 06:04 AM
    Morning,
    I'm just looking at the network properties for our testing SSID on each device.
    I have an Android 12 phone (Pixel 4a) which seems to get it nearly right, or at least hedges its bets ("WPA/WPA2/WPA3 Enterprise")
    Also an old Win 10 laptop which doesn't (just lists it as WPA2-Enterprise)
    MacBook 2021 Monterey which lists it as "WPA2 Enterprise"
    If I change the opmode from wpa3-aes-ccm-128 to wpa3-aes-gcm-256 then only the Pixel can actually connect - but it does then show it correctly as being "WPA3 Enterprise". The other devices can't tell me any info at all.
